Sounds,accelerator pump installed in carburetor is not working ,get it checked. The accelerator pump squirts and extra dose of fuel into the throat of the carburetor when the throttle opens. This helps offset the extra gulp of air that is sucked in until fuel flow through the metering circuits can catch up to the change in air velocity through the venturi (the narrow part of the carburetor throat). The accelerator pump may use a rubber diaphragm or a rubber cup on a piston to pump fuel through its discharge nozzles. If the diaphragm is torn or the piston piston seal is worn, the accelerator pump may not deliver it's normal dose of fuel. Or, if the discharge nozzles are plugged with dirt or fuel varnish deposits, it can restrict fuel flow.
