man i m having a prob in mehran " ist gear bhut agy ja ker left side per lagta hai not like normal or 3rd gear 1st gear wali jaga per lagta ha almost means ist gear left side per lagta hai kafe or 3rd gear almost ist gear ki side per lagta hai " and i m comparing it with the mehran having no prb in thr gear..plz solution batio......
shazi bhai u need to show it to mechanic ... gear transmission khol kay ... sahee keray ga and also get ur gear oil changed ...
ok yar whr gear transminssion ? yeh to nahi na is kay lia pora engine nikalna pery ga ? nd gear oil ka is say kai effect hai ?
nai engine nahi nikalna paray ga ...
gear oil change na hua ho sahe time pay it causes transmission to go out of order ...
ok yar i chked the gear needle now after seeing ur msg its in middle ..means less then desired value wht u would prefer that i shud change the oil ist nd then will it be ok ya phr wht u suggests or kitny kms per gear oil change kerna perta hia ..
gear oil shud be changed after every 50 thousand ... jahan tuk mujay mechanic nay bataya tha ... Althought am not expert... ... So , i had a mehran usski bhe yehi problem the ... yeh is liayay hota hai when a person hardly changes a gear ... get ur car checked from a mechanic he will help u out ... and wait for other pakwheelers to help u out too ... as am not expert i can only help u a lil bit ...
waisay mchanic do told me yesterday when i asked him abt gear oil he said ager gear mushqil sey lagta hai then get ur gear oil changed ...
humz..chalo anynwz thnx alot but any how i ll w8 for other PW comments
hello i think gear lever mean koe masla ha keon kah gear to theek lagtay han siraf jagah change ha is lea gear lever jahan say ap gare lagatay han us kay under i think rubber ki kit lagti ha chuck it asay he gear ka open karva lena mchanic ka kam to hota ha pasay banana thanx
han gear is working properly just slight change in its position for ist nd 3rd gear ok man i ll take me car to mechanic thnx..
@shazi_00
Yaar plz refer to mechanic i think its may be Gear Cross Problem its a small part under gear knob i think u hav to change it it very cheap and just 10 min work.
ok sir i ll nd i think to its prob under the gear lever but i ll go to mechanic nwz thnx a lot from all the PW's
brother u don need to get the gear oil changed simply go to the mechanic and ask to get him the bush relaced through lathe shop for the gear box and i hope it wud work
for more info plz contactneatautos@hotmail.com
ReagrdsWalleed
Neat Autos
get ur gear system inspected by sum expert first before u do something wrong causing more troubles, and try chaning the gear oil as well as other people say.
AOA
Brother i will suggest u that u have to check the foundation of Gear lever, inface i have faced this problem in my charade and in mehran too.
AOAI have Mehran 2010 .. gear is normal ..no soud in gear...but jab 4th gear sa 3rd ma down krta hn to gear nikal jata hai ...I dont understand k kia issue hai,,plz help
Get it che ked it must not be properly fitted in the axle/goda. Also get checked the plastic Hadi underneath gear lever
