Aoa. Today I opened Mehran Meter, whos lights were very dull. I cleaned each part of meter and installed LED bulb instead of ordinary bulbs, which cost me Rs.500 and also replaces glass as well. But I found no change, lights are still low but in white colour. What is the reason? How can I increase their power/light. Secondly, Fuel & temperature guage both have been out of order Plz help me or share remedy for it
I'm facing the same problem as well. I'm also planning to get the bulbs changed but as you've said there is no change, then I should wait for some suggestion or look for some other better option.
Yes problem it may be rely/cutout issue... Very soon I'll get check it from electrician and let you know
By the way, I contacted my electrician and he said that it'll be of no use to add some more bulbs or replace it with LED.
But I saw a Mehran with WHITE LIGHT ODOMETER which was clearly visible even from my car.
I think he got it completely changed.
Just visit speedometer wala and job done
wow...this is Mehran???
Can you please tell from where did you get this?
Thanks for the suggestion. Any good Electrician or shop from where i can get a good speedometer.
From where I can get this meter
