hi . My mehran 98 begin to shiver . when i drive it above 100km/hr . y is that.
1 - Get the wheel balancing checked. Tyres and Rims should be in good condition with no Jump in them and tyres teera na hoon.
2 - Your Disc Brake rotors should be in good conditon
mine shivers at 120 kph and problem is in disk brakes
ya.......vaqas.......wheel balancing could be 1 issue
whre could i find the best wheel balancing garage in islamabad................?
in F-10 Before shell petrol Pump .....where system wali shops r located :)..
mine brely reaches 100kms , and the shivering part happens at 90kms.
i dont thing it matter much cause i barely drive over 70 in the city !
This usually occur on motorways...........
go to wheels n wheels first plaza in blue area.
On a serious note get wheels aligned n balanced.check calipers that they arent lose.get all nut n bolts tightened.
anyone who says it can't go over 100 km/h should get in my car to get your answer. its stock.
My wife drives a mehran.its 05 vxr.39k mileage.165 tyres with 12inch rims.it goes over 120 on cng n around 130 on petrol.just regular maint.in short petrol pe meter maarti hae!suzukis have powerful engines.ever seen a suzuki pickup with 12 pasengers inside,3 at front.10 hangin outside.about 10 on its roof.total 35 adults in a 800cc pickup wooshing in hilly areas? Ul come 2 know da power of its engines!
Check the ends as well and bushes before alignment/ bal
Faisal
Verify wheel bearings and suspension bushes as well.
:o
I never seen 35 adults in one suzuki pickup 800cc in karachi.
try wheel balancing. check the condition of the tires
mai bhi yahi kehnay wala tha.
Got tyre checked ........... they have bit weared from one side .......but are usable................... nuthing tooo seroius ...... but some thing else is also contiributing to shivvering.......... i think zunny has over estimated suzuki engine . i thinkits engine is normal...........
yup its normal buit many people greatly under estimate suzuki
