[QUOTE=asad9798;4677257]The same starting problem occur when I parked the car on Petrol at night. In morning, car was taking the self but works very hard. I call the mechanic as engine, self, carburator are overhauled, cng kit cyclinder service, oil change by him. when the mechanic open the tappet cover, I was surprised that 3 springs (exhaust) backside were jammed. Mechanic told me that head sleeve etc (work by lathe wala) was not done properly. When I went to Lath wala ( Madina Autos near Naseerabad) who make its head, valve work etc told me that this problem is coming due to Petrol. I filled the petrol from HASCOL shahr -e faisal and car was working fine on Petrol. What is the problem which cause the tappet spring jammed?[/QUOTE
It was happened because of using rotten petrol,when you parked the car over night the valve got stuck due to viscous material (rotten fuel becomes sticky due to heat & gets hard after having cooled). Get the fuel tank cleaned and throw away fuel remove from the fuel tank.
