HIcan anyone suggest any additional checkup as my Mehran VX 2012 missing strokes in between 60-80 km/h speed, i have once cleaned up carburetor but still problem persists.
Hi..check it again..look for any lose pipes..it sounds like..it's not sealed against the inlet properly..
missing stroke ? whats' that ?? is it the car acts as HICCUP? check for ignition cables remove from plugs & re-insert properly. what did used for carb cleaning? i though VXR 2012 is Euro II compliant EFI ? is it still a carb engine?
Euro II just launched,initially 2012 is carb engine. ye i checked plugs and cables too. but problem is only at specific speed. after 80 km/h & before 60 km/h its run smoothly
ye, i double check that but its only at mentioned speed. otherwise it run accurately. now just thought its manufacturing fault and only rectified by replacing any part
