Both suspension variants are combined with a new electromechanical Direct-Steer system featuring speed-sensitive power steering and a ratio that can be varied across the steering wheel angle. This ensures excellent straight-line stability and, therefore, a high degree of assuredness when travelling at motorway speeds and makes the SL very agile. It also reduces the amount of steering required when parking and manoeuvring.
The new V8 in the SL 500 develops 435 hp from its displacement of 4663 cc and thus around 12 percent more than its predecessor despite some 0.8 litres less displacement. The fuel consumption has been reduced by up to 22 per cent. At the same time, the torque has increased from 530 Nm to 700 Nm - a gain of 32 percent. Although the displacement remains the same at 3499 cc, the new V6 engine in the new SL 350 develops 306 hp and delivers 370 Nm of torque. It uses just 6.8 litres of fuel per 100 kilometres, making it almost 30 percent more economical than its predecessor. Both engine variants come with a standard-fit ECO start/stop function. The 7G-TRONIC PLUS automatic transmission, which has been optimised in relation to fuel consumption and comfort, also contributes to the exemplary, low fuel consumption. The fuel economy of the BlueDIRECT engines takes nothing away from the roadster's raciness. Quite the contrary: the SL 350 accelerates from 0 to 62 mph in 5.9 seconds, making it three tenths of a second faster than its predecessor. The SL 500 takes just 4.6 seconds - eight tenths less than the previous SL 500.
The new SL combines its aesthetically honed profile, which follows the Mercedes-Benz tradition, with a luxurious feel. Fine materials, perfectly finished with great attention to detail, distinguish the style and character of the interior.
Compared with its predecessor, the new generation of the SL is much longer (+50 mm) and wider (+57 mm), providing more room for more comfort in the interior, too. Shoulder room (+37 mm) and elbow room (+28 mm) have been increased, exceeding the dimensions normally found in this vehicle class. Clear lines create a formally coherent internal space within this comfortable interior. Generously used wood trim extends from the centre console across the dashboard into the doors, creating a pleasant wrap-around effect. Three types of wood along with two different aluminium trim finishes are available. Perfectly in tune with the roadster's character, it combines the unpretentious atmosphere of a high-performance sports car with a comfortable, stylish ambience one comes to expect in a luxurious touring car.
The designers have brought the latest generation of the SL unmistakably to life on the basis of tradition but added new perspectives and visions. The result is a stylishly sporty and elegant luxury sports car with the classic hallmark SL balanced proportions: the long bonnet gives way to a compact passenger compartment that is set well back. A wide, powerful rear end giving the impression of raciness provides the finishing touch. A handful of elaborately styled lines define the powerfully sculpted and yet calm surfaces of the flanks. Finely worked details, a striking rear end as well as ventilation grilles with chromed fins from the dynamic traditional Mercedes-Benz design heritage visually emphasise the SL legend.
An upright classic sports car radiator grille clearly marks out the new SL visually as a prestigious member of the current Mercedes-Benz sports car family. The centrally positioned star is a contemporary reinterpretation of the famous trademark, which now extends into the centre section with its organically flowing contours.
