Hi @xulfiqar and everyone,
I have a Mercedes Benz, year late 1999, C180, W202. It has series of electrical problems. The worst problem so far that I am facing right now is to get rid of BAS light which is consistent. I have replaced the brake light switch, steering angle sensor, yaw rate sensor and lateral acceleration sensor.
I connected it with the Carsoft v7.4 code reader. My ESP is ok now and no error codes, however I still have BAS light in instrument cluster with error codes B1042 which refers to CAN communication error with BAS unit. The rectangular ESP warning lamp in instrument cluster never lit up since I bought this car.
With (ME) I get code P0341.
There were many other electrical problems related to PSE, EIS and Instrument cluster. I got rid of them after I replaced the old AGS battery with Volta MF100. Moreover car heater which was not working before now works fine.
I believed that other errors would also go away if I changed the Volta battery to some Imported ones like Acdelco and I did that and spent 25000 PKR to buy 100AH , 850cca SMF acdelco. Some of the electrical errors that I got rid of came back again when I connected the code reader.
Now I believe that Acdelco battery is plain rubbish.
Can you please recommend a battery for my Mercedes Benz year 1999, c180?
Battery Specs:
100AH
(L x W x H) 354mm x 175mm x 190mm
12V
hold type B13
