Hi Pakwheelers
I have toyota altis grande 2016 model. I am facing an issue with its suspension that whenever I go through a cat eye speed breaker at about 20 - 40km/hr I can hear a quite loud metal clunking sound from right side of suspension. The sound is like two metal pieces are constantly knocking each other. It is only noticeable on cat eye speed breakers or very rough road. I took the car to local mechanic, overhauled complete suspension, replaced all worn out bushes etc but the problem still remains. I also greased the caliper pins just to make sure but to no avail. I thought it might be exhaust pipe hitting the body or catalytic converter but both are properly fixed without any play etc
Have anyone else faced the same issue? I'll be very obliged if someone can help out in this matter or recommend a good mechanic from rwp/isb to look for this issue.
