Hi guys ,
I own a 2015 model mira eis ....it's bearing were making sound for the last couple of months so I got both front bearings changed ....after the bearings change , I'm facing several issues which I believe are interlinked
1. Car speedometer show higher speed than actual ....it increases to 100 while I'm driving at 60
2. The car looses pulses on higher speed i.e. 90-100(showing on Meter 135) , the car pulse looses pulse for brief moment and then it's back however the behavior is constant when driving on higher speed
3. Eco idle light is flashing and it's not working once the speed crosses 30 km/hr
I've got the abs checked and there are no error codes .
Got zero calibration done but still issues are there .
Got battery replaced a month ago so it definitely it is not the cause , removed terminal for 30 minutes but issue not resolved.
Mechanics keep telling me to buy kabli hubs which I'm not in favor off.
The trc light flashed initially after changing bearing and now it doesn't work.....it works up til the speed of 30 km/hr , after that the button doesn't work
Please advise way forward or a decent mechanic with a balanced head over his shoulders to identify and advise correct remedy (tired of jugaaro ustaads)
I am located in Lahore and can take car anywhere in Lahore
