Michelin, the company that invented radial tire technology, is once again changing the way the world moves with the introduction of PAX® System. An entirely new approach to the tire and wheel assembly, PAX System is already hailed as a vast improvement over current tire and wheel technologies.
The revolutionary anchoring system and an integrated run-flat system work together to give PAX System users a new level of performance and safety versus traditional tires.
Greater Safety and Freedom
When it comes to safety, PAX® System is way out in front of traditional tire and wheel assemblies. The most fundamental difference between the two is that a PAX System tire is designed to never separate from the rim, even with the occurrence of a sudden flat at high speeds under normal driving conditions. The inner support ring also offers exceptional maneuverability and control in the event of a blowout. And should a flat occur, PAX System allows for the vehicle to be driven up to 125 miles at 55 mph, which means you'll never be stranded on the side of the road.
Peak Performance All Around
Perhaps the most distinct advantage to PAX® System is its improved level of performance. When compared to a traditional tire, a PAX System tire possesses a shorter, yet more flexible sidewall for less tire roll, better road grip and more responsive control.
Driving Toward a Greener Tomorrow
Placing importance on creating environmentally responsible products has always been a priority at Michelin. PAX® System is no exception. PAX System tires consume 5 percent fewer materials in construction and offer a superior level of fuel economy compared to traditional tires thanks to reduced rolling resistance. PAX System tires, like all Michelin® tires, provide excellent tread wear for long life, are repairable if punctured in the tread area and have a reusable support ring. Additionally, PAX System completely eliminates the need for a spare tire.
