nana
corps commander is not jealous of your car (H) as he might be in armored BMW/ Mercedes/ Land Cruiser anyway. And I will not blame "seepahi". RP standing at MP checkpoint. they are the one first getting blown up and they are the one who just follow orders. If something happens inside the checkpoint.. they will be blamed and interrogated. also these checkpoints are monitored by CCTV by an officer at back end. I will not argue with those ghareeb seephai. I should give them the highest respect. standing there all day and night in hot weather at forefront of the threat.
Some one might have made complaint about the extreme noise caused by exhausts and that's the reason they are after it. in the developed countries even using a stock horn is not permitted. I hardly hear it. you will fail yearly inspection if your exhaust is modified. and you can be pulled over easily for lour exhausts. always happen here. It will go on your record. so if you put it back and cops pull you over again. they can impound your car as well.
anyway I belive your GF is in Cantt and maybe your "honay wala susar" is a army officer. My sympathies with you.
BTW.. my father served from 1970 till 1999.
Section 375. Equipment.
Subsection 31. Mufflers and exhaust systems. Prevention of noise.
Every motor vehicle, operated or driven upon the highways of the state, shall at all times be equipped with an adequate muffler and exhaust system in constant operation and properly maintained to prevent any excessive or unusual noise and no such muffler or exhaust system shall be equipped with a cut-out, bypass, or similar device.
No person shall modify the muffler or exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor or exhaust system of such vehicle above that emitted by the muffler or exhaust system originally installed on the vehicle and such original muffler and exhaust system shall comply with all the requirements of this section.
A muffler is a device consisting of a series of chambers or baffle plates, or other mechanical design for the purpose of receiving exhaust gas from an internal combustion engine, and effective in reducing noise.
An exhaust system is a series of mechanical devices for the purpose of receiving exhaust gas from an internal combustion engine and expelling it into the atmosphere.
