Make sure engine oil grade that is being used is 0w20, 5w30 or 10w30 maximum. These engines do not like thicker oils like 10w40 or 20w50. Tyre size should be within spec which is 155/65/r14. Higher than this leads to premature suspension failure such as bushings and shocks etc. Slight rust issues in the wheel arches if the car is not taken care of and paint issues also coming from neglect. Tailights and headlights tend to "yellow" out. A good polish and reseal with a UV spray applied correctly fixes the problem.
