What ? ATF in CVT? Change it immediately or you will ruin your transmission. You have to use CVT fluid for CVT transmission. Do not drive your car anymore or you will ruin your transmission which will cost you around 2-3 lacs. I think daihatsu also uses toyota CVT fluid. Go and replace it in first place and then if you still have issue then you can go for general tuning which includes fuel injector check, fuel pump check, catalytic converter cleaning, spark plugs etc. But PUT CVT FLUID IN T
YOUR TRANSMISSION at first place.
