Best find someone with a pressure tester to pump the system up to 16 psi and see if it holds pressure.
You have a very miniscule leak somewhere.
Also check the waterpump bleed hole, a little bit of coolant leak is ok as its built in the design, but a large amount of buildup usually means the pump is bad.
