Hey guys!!!
I just bought a Mira ES and was worried about its Eco idle not working so here are some of the things which you could try to get it working
1.Make sure your air bags light switched off after few seconds of engine start
2.Sealt belt is fasten
It should work with above conditions reached ,still if the problem persist,then try what I tried..
Open the car bonet,and detach the terminal of car, (+) for about 15 seconds
this is just for resetting the ecu and the eco idle chip
Now eco idle should work. still not working then go to a electrician and asked him to check the connections of the lithium ion battery under the back seat. As these cars are imported and have to stay for months without use.. so some do detach the wires befores sending.
Any questions would be appreciated
