How much brake pads costed u? Which brand?
Unbranded for around PKR 2,500 for front wheels only. I couldn't find any detail on what brand to go for and where to get them from so stuck to a simpler choice.
Why do u think alignment is needed? Is the car moving to a side when leaving the steering?
And who told you about steering alignment?
Keep using 5w20 oil and dont listen to mechanics at all... Dont change the grade even at 100k km.
- why do you think meter may be reversed? Are you the first owner? When was this 2015 model car imported and registered?
- If u r 2nd owner then at what km did u purchase it?
- After these info i can guide u how to make sure the mileage is true on ur odometer.
Assuming it genuine mileage, then replace the CVT transmission oil. Make sure its the correct type, which would be mentioned on the cvt dipstick.... Dont put any ATF oil... DONT...
Yes. The car consistently shifts right when the steering is dead straight. Steering alignment is just some random thing experts (read: ustaad) talk about!
I'm not the first owner. I got it from a local dealer with about 20,000 km on the odometer. One of the tyre had a damaged wall at 38k only and that alarmed me. I expected the set to last 50k ~ 60k at least.
Thanks for the advice on transmission oil. I will be on the lookout.
