Guys the radiator is fine. the gasket is gone for sure. because there are minor traces of engine oil in a freshly filled radiator. and once the engine is started up constant flow of bubbles can be seen in radiator.
Is it worth getting this engine repaired gasket changed/head phased etc? will it be good once it is fixed or after some time it will go back to heating up?
Should i get new engine(head assembly) from bilal gunj? if yes... how do i make sure the engine i am buying is good and not repaired or used for 200k~300k km. I came across horror stories that after people got engine from bilal gunj either it's gasket blew in a month or so... or it was reducing engine oil.
Lastly do you guys know a good mechanic in lahore that can either repair or do the engine swap?
Thanks for help.
