Salam everyone!
I first faced the problem about a month back. Took it to a mechanic, he changed the gear oil and cleaned the gear filter. As per him the gear oil had become too dusty hence resulted to lack power. The problem fixed at that time and worked for nothing more than a month.
After one month the same problem occurred again. Although, during tht time of one month i did feel heaviness in gear shift, as it was not that frequent. The gear shifts were with bumps and specially the reverse gear used to shift after 2 to 3 seconds with a certain bump. Then one day the major problem occurred. I took it to the same mechanic, this time he and his gear expert mechanic suggested to change the gear box as the oil pump is not working properly.
Now I am confused and reluctant to do so and basically unable to believe the mechanic. Please guide me and suggest how to proceed.
Regards
