Car = Civic 8 gen 2011 model
Car was missing/jerking while driving. Mechanic said try disconnecting the O2 sensor, if missing goes away then O2 sensor needs replacement. I disconnected the sensor and car now ran smoothly.
Problem is that now after replacing the sensor car still misses/jerks. Replacing the sensor didn't solve the issue. Disconnect the sensor and it runs smooth.
What could be the issue.
Things already tried:
- Spark plugs changed
- Fuel injectors cleaned
- Throttle body cleaned
- CAT is already clean
