I was facing the same problem. Specially jab ac k saath break lagao or is say pehaly keh car ruk jae, engine boht zor say shake hota hay or kuch daer kay liye engine ki check light on ho jati hay. May nay detailed tuning karwai, throttle body cleaning, map sensor replacing, injector cleaning, plugs new dalwa liye, engine oil, oil filter, air filter, condenser cleaning, radiator cleaning, sab karwa liya, ultimately jab may nay compressor expert mechanic dhoond k usko test karwaya to pehlay to pata laga keh compressor weak hay jis wajah say woh load zyada lay raha hay. Compressor to gas recharge pay kharab ho chuka but another factor is car engine mounting may say agar koi aik mounting toot gaya hay to bhi car engine unnecessarily vibrate karta hay. And last suspected problem is that your car engine gets weaken, the head assembly needs to be replaced. It depends upon how wisely you investigate and observe keh problem kya ho sakta hay. Compressor and head change karnay kay elawa baki sab chotay chotay kaam hain jo normally car maintenance ka part hotay hain. so you better judge which could be the suspected problem.
