Its quite hard to believe someone in their right minds would swap a 2.4 GDI engine into a Galant in Pakistan that was sold by Dewan motors, even why would someone swap a GDI into an older JDM Galant GDI anyway, its a known problematic engine in Pakistan. I have done many swaps in GDI Galants but the engines were
4G63
6A12
6A13
All were available quite easily, I used to get the rest of the "required' bits too like full wiring, AFM, airbox induction pipes etc. Correct swaps require part removal of the dashboard, full console removal and spidering some wiring for the "manual shift" autobox to work. Otherwise it behaves as a standard auto.
The walnut blast procedure is done via the spark plug holes and a vacuum attachment from the injector hole, the piston top is blasted with shell to dislodge all carbon and then vacuumed out. There are workshop tool adapters by Mitsubishi but not available in Pakistan, ME, Africa or any of the Americas.
