@garrisonian...
sure thing...
thankyou!
[highlight]2007 Mitsubishi Galant
Year: 2007
Make: Mitsubishi
Model: Galant
Engine: Location Front
Drive Type: Front Wheel
Price MSRP: $19,899.00
Invoice: $18,979.00
Weight 3428 lbs | 1554.9 kg
MPG City: 23
MPG Highway: 30
Engine
Engine MIVEC: 4G69
Aspiration/Induction: Normal
Displacement: 2.40 L | 146.4 cu in. | 2399.5 cc.
Valves: 16
Valvetrain: SOHC
Horsepower: 160.00 HP (117.8 KW) @ 5500.00 RPM
Torque: 157.00 Ft-Lbs (212.9 NM) @ 4000.00 RPM
HP to Weight Ratio: 21.4 LB / HP (Vehicles with similar ratio)
HP / Liter: 66.7 BHP / Liter
Bore: 3.43 in | 87.1 mm.
Stroke: 3.94 in | 100.1 mm.
Compression Ratio: 9.5:1
Block: Cast-iron
Head: Aluminum
Optional Engine
Engine Configuration: V
Cylinders: 6
Engine MIVEC: 6G75
Displacement: 3.80 L | 231.9 cu in. | 3800.8 cc.
Valves: 24 valves.
4 valves per cylinder.
Valvetrain: SOHC
Horsepower: 258.00 BHP (189.9 KW) @ 5750.00 RPM
Torque: 258.00 Ft-Lbs (349.8 NM) @ 4500.00 RPM
HP to Weight Ratio: 13.3 LB / HP
HP / Liter: 67.9 BHP / Liter
Redline: 6500
Bore: 3.74 in | 95 mm.
Stroke: 3.54 in | 89.9 mm.
Compression Ratio: 10.5:1
Fuel Type: Gasoline - Petrol
Block: Cast-iron
Head: Aluminum
[/highlight]
CHEERS!
