This post have been updated as of 31-01-2016
Salam to everyone
bought Mitsubishi i 2006 in september 2015. car was in bad shape performance vise as the previous owner was i guess 100% paindu and didnt knew how to keep a car maintained. just got these parts from UAE and From japan.
From UAE:
CLIP Mitsubishi MU481130 - Installed
BUSH, RUBBER FEBEST MSBHA3F - Will Install Soon along with rear arm bushing front arm (febest part number MAB-066)
STABILIZER FEBEST 0423HA3FL - Installed
SEALER FEBEST MCP001 - Installed
FILTER, OIL Mitsubishi 1230A040 - Installed
STABILIZER FEBEST 0423HA3FR - Installed
SPARK PLUG Mitsubishi 1822A011 - Installed
From Japan
COVER, END, PLASTIC Mitsubishi 8202A005 - Installed
HOUSING, PLASTIC Mitsubishi 8030A028HA - Installed
COVER, END, PLASTIC Mitsubishi 1375A078 - Installed
FILTER, AIR Mitsubishi 1500A113 - Installed
THERMOSTATE Mitsubishi 1305A082 - Installed
BELT Pitwork AY14051480 - Installed
GASKET Mitsubishi 1035A486 - Installed
FILTER, AIR Pitwork AY684NS025 - Installed
CLIP Mitsubishi MR720431 - Installed
VALVE, AIR Mitsubishi 1035A200 - Installed
just wanted to know about few small things.
after how many kilometers should i change the genuine oil filter and air filter???? (they came expensive lol). UPDATE : mitsubishi suggest u should change it after 12,000 KM
already installed new AC filter which comes with a mileage of 12,000 KM
also where can i get the ATF for this car??? UPDATE: you can find it anywhere, i just got the dexron atf sp3 3 Liters with filter cleansing
also please advice how to drain the radiator coolant and ATF (flushing also) UPDATE: there are two flushing points underneath the car. front side. 1 liter coolant 3 liter water
i can be contacted anytime via email hamzairshad@gmail.com
replies will be deeply appreciated
loving this tiny beast by the way
make sure to check the next posts for pictures
