The waterpump is almost installed for the life of the car. I too have the same and on factory spec no issues at all.
Check for Fan Speed for both the AC fan and the radiator fan. And why is the thermostat not present?
There can be other reasons... Have you scanned the car are there any error codes. What temp does the needle shows you.
Go to a service station and ask the guys there to pressure wash the AC condenser and the radiator with the pressure washer. What coolant are you using? Check if there is any slight leak in the water body. Also change the coolant to Caltex and bleed the system. Use either distilled water or meetha pani. Never use khara Pani. Also check if you engine oil is milky and if the car has been giving any white smoke in the initial startup.
Best of luck!
@taimurahmed92 sir do shed some light you too have the same model probably...
