Oh, so much in so little time, where do I start from....... 1st of all as long as we have C.U.G (close user group) I don't mind seeing the FJ rebuilt here. After all Shah jee has been an owner of a Mutt and there's no way even he can compare the FJ with the greatness of the Mutt
+ MOCK evolved into MOCP & now I think it should further evolve into KJC.
Kamran, correct me if I have understood wrong, you want to know if you can put in another distributor & continue to have 24volts. Yes you can as long as you get a 24 distributor. Even if your alternator goes bad, you can put in a land cruiser 24 volt one & it'll work. Have you changed the alternator also ?
Carb looks set, had the return line in it na ? Show a pic from a distance.
