Oh, so much in so little time, where do I start from....... 1st of all as long as we have C.U.G (close user group) I don't mind seeing the FJ rebuilt here. After all Shah jee has been an owner of a Mutt and there's no way even he can compare the FJ with the greatness of the Mutt
+ MOCK evolved into MOCP & now I think it should further evolve into KJC.
Kamran, correct me if I have understood wrong, you want to know if you can put in another distributor & continue to have 24volts. Yes you can as long as you get a 24 distributor. Even if your alternator goes bad, you can put in a land cruiser 24 volt one & it'll work. Have you changed the alternator also ?
Carb looks set, had the return line in it na ? Show a pic from a distance.
[/quote]
That's gracious :), if KJC is the target then CUG would need lots of expansion :). Mian Sb. sounded very busy today but I am expecting good progress on the FJ.
Sarmad, you are very much right saying that Mutt greatness can not be compared with other jeeps. So far the jeeps I had and the one I have driven, Mutt is amazing in its own way. Amazing suspension, amazing ride and brillient in off roading (dry), as never used it in mud or water. That is why where ever I still see any Mutt around, I share pictures with current owners and lovers.
I tried the break oil formula one a small portion, right side next to the rear wheel arch, if you can figure it out in the picture. Not polished yet.
Basharat, busy with the big guns, not with the jeep yet.
