Habibi, it depends what is available in the market and what denter is capable of doing...I don't see any reason of cutting anything as this vehicle is designed to take all panels from its different versions, depending on year of manufacture though.
The only difference I can see are two hinges at the lower panel in soft-top versus single hinge in a hard-top version.
If you can find full frame doors that can be split /unbolted like this
you can fix them to your existing lower panels. Otherwise new points for hinges on tub will be required to be grounded.
