Installation is straightforward and easy.
Our motorcycle air conditioning unit can be mounted on most any rack the motorcycle has with our universal adapter. Or, we have developed a ”soft” mount for easy and flexible mounting on the rack, back seat or elsewhere. And you can simply take the unit with you or stow it in onboard cases.
The power is drawn from the bike’s electrical system only. Connect the power cable directly to the battery. Note that you should check that your motorcycle’s alternator is strong enough to power the A/C. Our current A/C model is designed for heavyweight bikes with engine size larger than 650 cc. See the Manual for detail.
Motorcycle Air Conditioning by EntroSys
//youtu.be/http://www.youtube.com/watch?v=LnEibndWyQU
