Hello Guys Now Bike Is Filled With Liqui Moly :)
I Am Liking The Smooth Ride Of Bike & Now I Am Relaxed It Is The Genuine Oil
Filled In My Bike I Mean You Can't Do More Than This For Your Bike
The Initial Sudden Only Change I Am Noticing Is Engine Is More Smooth
I Can't Comment On Heat I Tested And Gave Full Throttle To Bike And Drove It
Mix Few Km's On Highway & Few Km On Clean Road At Full Throttle
I Did Not Feel Any Heat From Clutch Side Engine Cover But Obviously When Came Back Home
Engine Was Hot I Did Not Feel Any Huge Difference Its So Quick To Comment On That
But I Think It Will Be Clear Now Within Some Days I Do Some Time Feel Heat On My Right Foot
Which Is Near To Clutch Side When I Drive Bike In City Lets See If I Now Feel With Liqui Moly
Alteast In Todays Few Km Drive I Did Not Feel Any Heat What A Specially Liked Was Smoothness Of Engine
Engine Is More Smooth Now As Compare To AHl Which Shows Oil Is Successfully Performing
Drained AHl Oil After Around 800km Believe Me Mechanic Was Saying Why Are You Changing Oil
The Oil Came Out Was So Neat & Clean And Always My Bike Drains Clean Oil
I Showed Mechanic This Liqui Moly Oil He Said Han Yeh Kon Se Balaa Hai
He Liked The Oil But He Really Liked The Bottle And Request Me Please Give Me This Bottle
I Will Use It For Chain Lube He Was Loving That Straw
Seriously Speaking While Pouring Oil He Was Adoring It Although He Is Local Mechanic
He Is My Friend & I Mostly Go To Him As He Takes Time & Completely Drains Out It Till Last Drop
InshAllah Will Drain This OIl After 2000km Will Inspect It After 1500km
But I Think It Should Easily Do 2000km Even AHl Oil Has Successfully Done 1400km
Here Are More Pics I Opened The Box Inside The Box
Obviously Two Liqui Moly Bottle But An Email Paper Was Also
There Which Included Bunch Of Liqui Moly All Products Catalogue/Brochures
Bottles Were Wrapped In Huge Liqui Moly Shopper Bag :)
As I Opened The Cap This Funnel Came Along With It
And Yeah Certainly As Other Fellows Told It Is Very Annoying & Slow Process Filling With This
But It Is Easily Removable Can Be Removed By Pulling It Up
It Was Again Some What Slow Pouring Oil With This Too But Not Annoying
I Asked Mechanic To Remove It He Did His Best Pulled It
But In The End He Said Bus Sahe Hai Yeh Esko Remove Nahein Karte
I Had Set The Quantity Level At Home For Pridor 100 After Filling Oil
Dipstick Showed Oil Level To Upper Level Which Is Perfect
It Is Remmended In Manual To Keep Oil Level To Upper Level Mark On Dipstick
