- No such thing as tuning, rather routine\periodic maintenance is required.. that includes change or engine oil, oil filter and air filter every 5k km.
- Cant tell cause I'm frm khi
- 5w30 should be the best. Look under the bonnet for a sticker that has oil grade mentioned on it.
- Whats the total mileage? Maybe it gets better once you get all ur fluids and other regular parts changed (this should be done as soon as you buy a used car, so that it starts a fresh maintenance routine from you). It includes
engine oil, transmission oil, spark plugs, brake oil, brake pads (if req), coolant, wiper fluid.
The acceleration would be sluggish still yes, due to smaller engine and being automatic.
Is it CVT or 4AT auto? Be careful of what trans oil you are Changing in it.. both oils are different fr different transmission.
5-No need, unless you have the turbo engine in it.
6-Yes pls dont disturb anything. You may get your scanned though on a computer to check if all parameters are in their required ranges
