Hi guys...i have MOVE 2015 but now a days its AC doesn't work properly when car is P or N mode but its awesome during ride...any suggestion plzz
You have to live with it. Mostly it is the problem for JDM cars in these starving summers.
Thnx
Does Passo have the same AC issue that AC doesn't work in P or N?
I have Move aswell same issue, i dont know why these cars ac works in P or N mode.
This 2018 there should be seperate rooftop ac for small cars or dual air conditioner.
I have JDM Wagon r 14 model. Same issue. Ac does not work on P or N mode. Got my compressor changed as it was making noises but still the same issue no cooling on on Idle. Cooling is ok when car cross 1500 RPM.
its not problem with jdms...
this is problem in some vehicles...where the RPM does not go at required level when car is at idel....check with efi electrician or ac mechanic
