I've found the wiring diagram of this three row ecu.
Pin 31 is ignition
Pin 63 is kline
And 111 is chk engine
Di is 112
I couldn't figure out what tx and rx means and where they should be connected.
Going to ameer and get it connected is very easy solution but i want to work this out myself because it's my own car.
Obd2 connections
Pin 1=chk engine
Pin 8= ignition
Pin 7 = kline
Pin 16=+12v
Pin 4&5=ground
Pin 11=tx
Pin 12= rx
Pin 13=di
Now I've found di
But what is this tx and rx?
If i connect this to elm327 scanner and use nliteII and just connect K line and chk connections with ground and battery will this work?
