Navigation sd card is working fine and all functions are fine in NSCP-W62 but when i enter sd card with mp3 or wma songs it shows error " SD CARD CANNOT BE USED" pics attached. i have formatted card in FAT 16 as well as FAT 32 format but same result. Tried using 3 cards but same result for all. SD cards are working fine on laptop and on mobile. Plz help .
This navigation only support micro SD-HC. Purchase sd card of some good brand on which (HC) is written. Otherwise it will not work.
Thanks i'll try that
hello brotherhave you found any solution? i have the same problem
Not yet and no one is replying ...... if you found any solution do tell me. thanks
Have you found any solution for SD Card Support on NSCP-W62?Also are you able to play mp3 on CD-R disc?
Yes mp3 cd is working fine but still no luck with sd card
NSCP-W62 Car Player only support "Micro SD-HC" memory cards
Tried SD-HC card of class 10 and class 4 as well but still not working. If your card is working then pl share its pics
Use MicroSD card with SD jacket and it will work!
still not working
any one using sd card please post pictures of sd card
Found solution for this problem.Software cad / nav card does not support TV & SD card option that is why it was showing error that "sd card cannot be used". I cahnged the software card and music sd card is now working fine.
from where to buy this software card / nav card? Also will this also make the radio functional as well? This is because my radio is also not working.
Try 2 GB card
what did you change? the bootable sd card? and from where did you get it?
AoaWhere did you get the navigation card?
