Ohhh....So ur finally Feeling Auto Effect On Your Pocket
5AFE Is Heavy On Auto Tranny anyways....!!
What Do You Mean Down On performance....Pickup issues??? Missing Or what???
Things You Need To Check
Map Sensor
O2 Sensor....Its Busted For Sure...70%
TPS Adjustment.....
Timing Adjustment With Timing Gun
How To Check For error Codes
There Is A Little Box in Your Engine Room Saying "Diagnosis"
Open It And Take A Piece of Wire.....Short The Following Points.....TE1 And E1
Put Car On IGN....(No Crank) Just IGN
If You Have Error Codes....Your CEL Will Blink In Pattern....For Eg If You Have A Code 21
It Will Blink Two Times....Then Stop For Some Seconds And Then Blink one time.....!! mean 2 1...makes 21
You need To Count No Of Blinks .....Be Patience Will Doing it...and Recheck once you are done to confirm it...Once Done...remove the jumper wire again
If There's Next Code..It Will Do Same For Next Code....If Its Only One Code...It Will Repeat Pattern Like This
If There's No Code....It Will Blink with No Gaps And Interval...
Its How You Read Error Code
Good Luck Tuning Yours......Doing Same With My Ae101 Nowadays....!!
