[edit] B3
1.3 L (1324 cc, 81 cu in) B3 - (71x83.6 mm). It was available in SOHC and DOHC variants and was found in the Kia-built 1988-1993 Ford Festiva, the 1987-1989 Mazda Familia and the 1987-1989 Ford Laser, and 1994-1997 Ford Aspire. Later variants were used in the Mazda Demio microcar as late as 1999.
Horsepower: 63 hp (47 kW) @ 5000 rpm Torque: 73 ft¡lbf (99 N¡m) @ 3000 rpm
[edit] 4K
The 1.3 L (1290 cc) 4K was produced from 1978 through 1989. Cylinder bore was 75 mm (2.95 in) and stroke was 73 mm (2.87 in). It was a 8-valve OHV engine.
In 1980, the 4K produced 60 hp (45 kW) at RPM. From 1982 through 1984, output was 65 hp (48 kW) at 5600 RPM and 72 ft¡lbf (97 N¡m) at 3600 RPM.
The 1981 and 1982 California-spec 4K-C produced 58 hp (43 kW) at 5200 RPM and 67 ft.lbf (90 Nm) at 3600 RPM. Torque was up to 74 ft¡lbf (100 N¡m) at 3400 RPM for the fuel injected 1982 through 1984 4K-E. The Japan-spec 4K-U produced 74 hp (55 kW) at 5600 RPM and 78 ft¡lbf (105 N¡m) at 3600 RPM in 1982.
Applications:
Toyota Corolla
Toyota Starlet
Toyota Liteace
Daihatsu Charmant
Toyota Kijang/Second Generation Toyota Tamaraw
In the Philippines, these engines were also used on locally assembled owner-type jeeps.
