When I start the car it's started ok after 10 minutes when the car is heated its accelerator is not working and shaking also rpm is not stable.its engine is turn off after it.when I try to start its not starting till it's cool down.what is the main problem..fuel pump is ok.when i remove the radiator fan sensor then it's work fine.i also performed its tunning from suzuki authorized dealership 2 weeks ago.on petrol it's work fine but on CNG it give the said problem.
Any error code? Does start cranks the same way when it's cold?
No error code.when engine is off it showing check engine
Get it scanned andCheck ignition system.
I checked everything is ok
Then ECT might be bad if it start working without it. Bad ect can cause ecu to go in limp mode.
Bro ghari start ho jati hai normal.jab temp increase ho jata hai aur temp gauge pe needle middle pe ponchti hai to accelerator missing s krta hai aur car band ho jati hai.us ke baad start Nhi hotiJab tak cool na ho jae.aur jab start dobra ho jae to 30 hours tak koe prblm Nhi ata.per jab ghari ko 30 hours tak na chalaye per ye prblm start ho jata hai.agar radiator fan ko auto se direct kar le per ye prblm nhi krta.reason kya hai
Does your car is heating up?Have you done any work recently?
your city?
Mianwali
Not heating and after this problem tunening performed from suzuki authorized shop.but still the problem exist.
Fuel pump problem maybe
If the problem exist due to fuel pump why it give the same issue with CNG.
No it will not give issues with CNG if you fuel pump is bad... I will suggest to have the car scanned for error codes...
Because fuel pump is not responsible for delivery of cng only petrol
What is meant by error code
I discussed with several mechanics but no one was able to solve the said problem.
An error code is lodged in the ECT (card) of the car. when you connect a computer to the car with the OBD2 port it will show you the error codes which will lead to the exact fault...
I am very much sure it is an electronic fault...
Ok i will try this.let see what's happen
Bro did your problem solved? I have same issue with my cultus 2011 model? Many mechanics checked but no one can solved the issue. Please reply
