I sincerely hope you washed the grease from the bearings you installed, it will plug up some oil galleries as the engine never gets hot enough to melt bearing grease.
A few drops of engine assembly lube or moly assembly paste is recommended in these bearings after a good wash with solvents to clean the prefilled grease.
