Bhai bohat wait ho gya !! aaj laga do pics
Wish i could... bus anqareeb laga dunga InshaAllah once i receive and install the lights
Waiting
Desperately waiting...anxiously waiting....
I am sorry for the delay. I had to rush to Islamabad for some urgent piece of work. I'll get them these test and installed by next week InshaAllah
Yaris kahan se agai?
Dair aaye durust aaye. No hurries
Looking to buy LED indicator bulbs, seeing as BI-LED don't sell them anymore, where else can i get 2 pairs from ?
Any luck with AliExpress?
It's a bit confusing there. Alot of options to choose from. Any link ?
I heard iJDM ones are good
Will take a look at them. Thanks.
I have found a couple of good options but was watching a video where the guy said that the LED's which have load resistors built in start hyper-flashing after some time ? Have you tried turning your hazards on for a minute or so ? Do they work normally ?
Hyperflashing occurs if you replace all indicator bulbs with LED indicators. Also, bulbs start to hyperflash after 2 minutes and it only happens when one side blinker is on, bulbs don't hyperflash on hazards .
I am going to replace all four corners. Should i get the relay for LED flashers or should i be good. I don't think one would use indicators for more then a minute, if that. So far i have three options. The following two and one is a shop in Lahore which a member suggested, have asked a friend to check them out and report.
https://www.aliexpress.com/item/4000510477764.html?spm=a2g0o.cart.0.0.2ab33c00SmWabB&mp=1
https://www.aliexpress.com/item/32909526847.html?spm=a2g0o.cart.0.0.2ab33c00SmWabB&mp=1
Update for the headlights?
No need to get relays if you're ok with the 2 minutes interval. I gave been using them for 2 years and i don't find any problem them. Get the ones with built in load resistors.
They're on way to Lahore. Will recieve them tomorrow
Will you fit them yourself?
