Thanks for mentioning haseeb bro. Well the thailand spec OEM Koito LED headlights are good no doubt but when compared to a Proper HID projector retrofit like the one you said of Mini D2S then the Retrofit wins handsdown due to the following points:-
1. By going with Mini D2S retrofit you get Bixenon capability. So technically you will get 4 high beams combined.
While the Thai spec OEM LED headlights are LED projectors low beam only.
2. By going with Mini D2S retrofit you get wide variety selection of D2S HID Bulbs with different kelvin temperature(color). While the thai spec OEM LED headlamps give out whitish 5500k-6000k output only and you can not change the bulbs as the LED projector itself is a one complete unit.
3. By going with Mini D2S retrofit you can select different ballasts with different watts output according to your liking or brightness. But i only recommend OEM HID ballasts like Denso,Koito,Hella etc as OEM 35w is more than enough. Also OEM HID 35w is brighter,reliable than aftermarket HIDs.
4. By going with Mini D2S retrofit you get better brightness and useable light on the road. Personally tested both HID projectors wins.
Now the only downside with Mini D2S retrofit is that you will need to slightly trim the low beam reflector in order to mount the projectors properly. Because Mini D2S projectors were designed for H4 based headlights.
I hope it this information narrows it down for your decision. Good luck
Sent from my SM-J700H using PW Forums mobile app
