Its 1997 model purchased from my father's friend...
does it have cng?
Yes it have ac and cng..
I hope you won't mind sharing its cost
a very clean 97 model can be found in 330-350k and 375k-400k for margalla plus same model
Pm sent
@margallar brother, g15 kaisa engine hai? avg ktni dyga? mai apni margalla me dalny ka soch ra..
g15 is a gas guzzler
:o bhai m ny yehi suna k g15 ki petrol avg achi hai 14, 15 hai, n gas py b fit hai..
G series is outdated and inefficient
mtlb? asaan ilfaz me, m chitta unparh in automotives..
G15, though an old engine but is tough fellow. i swapped my G13B with G15A and am happy with it. good low end torque and if set up properly will make u smile every time you start any journey. you will have to find a good electrician for wiring and setting the ECU. G15 comes with an auto transmission and you will have to change the gear box to manual. since the ECU is paired with an auto tanny hence the electrician will have to alter some wiring. you will have to pay attention to auto choke setting, ac and rpm when on idle as it will test the skills of he person working with it. mileage is not 15km but around 10-12 depending on the way you drive. on long routes you may get a little better avg but this thing really moves when you press down on the throttle and you can easily reach speeds of 160km/hr on motorway. having said all this you will have to search real hard in order to find a good engine as there are quite a few vultures out there...
Matlab fazool petrol avg
Bro but as far as i know, G15 can be fitted with least amount of alteration.
I am not familiar with K series engines and are they available in country these days already? How much does the swap is expected to cost?
old tech is old tech after bro g15 have almost hp as m13a but still m13a hae more high end torque (mean more speed) and almost same lower end torque (mean almost same pick) but m13a is more efficient and more cheap as well plus no expert electrician required to get the ecu wiring correct the only is g15a suit margalla or baleno is its bolt to bolt on these car nothing else
g15 will need no alteration in engine mount but you may need to alter excels/cv joint not sure about k series engine but k series engine are way lot more efficient than g series engine
bro if you don't mind plz pm as well
@saboor73 @margallar so iska mtlb g15 na dalu, phr knsa engine better rahy ga?
bro just run it on stock engine
engine is weak, needs complete overhauling, drinking engine oil jaisy havoline factory mery papa ki hai, nd also nt giving petrol avg more thn 7-8kmpl
