Salam all,
I have a Santro Club on me, the car has done 14K kms at this point. I have had a great time driving the car and strongly believe for a 1000 CC it performs remarkably well.
Just recently I have started to witness a problem that is pain in the ass now! As it stands, I cannot drive the car without the A/C turned on as it would heat up. Apparently, the fan doesnot trigger at the appropriate temperature, pulling the temperature needle very close to the bloody HOT area. This is the point where I turn A/C on, the fan starts immediately taking the car temperature to normal and it continues to be like that till the A/C is funcational. As soon as it is turned off, the bizzare pattern repeats!
Afore-mentioned text explains the problem but its pertinent that I quote a bit of repair history of the car, that might help you guys diagnose the acual problem.
In the cars early days, once it stopped by itself and the engine would just not start
The next day I discovered that the car would not start on petrol and ran perfect on CNG. I took it to Hyndai Motors based in Thokar and got it inspected. Witnessed two engineers with conflicting views, one would say that the ECM needs to be checked and the other would not buy his idea and said that the car wirings needs to be assured off before placing hands on ECM.
And hey presto! the problem was fixed, and the car would start on petrol and convert to CNG, Great stuff. I was charged Rs. 500 for the repair and when questioned about the issue the latter engineer goes:
"Aap ki GRIP main masla tha, us main 3/4 wires hoti hain jo engine main ja ker kehin lagti hain, un main sey aik wire sai attach naighn hoi vi thi isi liya poora current naighn tha jatta, aab set ker di hai, geuine fault tha"
From that day, the car has been acting up on me bigtime! Every now and then it would heat-up slightly, I would see the temperature needle cross the 2nd dot but would come back sooner than later, but it definitely was crossing that 2nd dot on a regular basis.
The situation grew worse with time till this stage when I cant get drive the car without the A/C turned on. I have been to the same service center and they say they car has no problems, for some funny reason the car would not heat infront of an engineer and would as soon as I took it back. Anyways, I got it thoroughly checked last week and the engineer goes
"Sir masla dhoond liya hai, GRIP ki aik wire main play hai on both ends, woh hissa jo GRIP main lagta hai aur woh wala bhi jo engine main, he took a glue and as per him fixed the problem"
I drove away safely for 4 days and the bloody problems started to recurr again. I am sick and tired of this problem really and need to get it sorted as a matter of urgency. Can experts especially Santro owners please drop me a line with regards to this matter. Do you reckon the engineer have diagnosed the problem correctly? If yes, may be they could not properl fix the play in that GRIP wire? Desperate for suggestions.
Best Regards
Ahsan
