I wana be King wid B King
Check Details
http://www.suzukicycles.com/Products/GSX1300BKAK8/Default.aspx
Specs
Engine: 1340cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC
Bore Stroke: 81.0 x 65.0mm
Compression Ratio: 12.5:1
Fuel System: Fuel Injection
Lubrication: Wet sump
Ignition: Digital/Transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2160mm (85.0 in.)
Overall Width: 810mm (35.2 in.)
Overall Height: 1040mm (40.9 in.)
Seat Height: 815mm (32.1 in.)
Ground Clearance: 110mm (4.3 in.)
Wheelbase: 1515mm (59.6 in.)
Dry Weight: 235 kg (518 lbs.)
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, adjustable rebound damping and adjustable compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, adjustable compression & rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 200/50-ZR-17
Fuel Tank Capacity: 16.5 liter (4.2 gal)
Color: Gray/Silver, Black/Matte Black
