This is the bike which I'm dying to get a hold on..InshAllah will buy this bike and take a road trip all around Australia..Its a Yamaha Midnight Warrior..share yours too, I mean fantasies
Engine
Type 102-cubic-inch (1670cc) air-cooled 48° V-twin; pushrod OHV, 4 valves/cylinder
Bore x Stroke 97mm x 113mm
Compression Ratio 8.36:1
Carburetion Twin-Bore electronic fuel injection; throttle position sensor
Ignition TCI
Transmission 5-speed close-ratio; multiplate wet clutch
Final Drive Belt
Chassis
Frame Aluminum monoshock
Suspension/Front 41mm KYB inverted fork; 5.3-in travel
Suspension/Rear Single shock; adjustable preload and rebound damping, 4.3-in travel
Brakes/Front Dual hydraulic disc, 298mm
Brakes/Rear Hydraulic disc, 282mm
Tires/Front 120/70-ZR18 Radial
Tires/Rear 200/50-ZR17 Radial
Wheels 5-spoke cast
Dimensions
Length 93.9 in
Width 36.8 in
Height 44.1 in
Seat Height 28.1 in
Ground Clearance 6.1 in
Wheelbase 65.6 in
Dry Weight 612 lb
Fuel Capacity 4.0 gal
