hi fellow,
being an owner of vxri for the past 1 year my observation is that..... these are not typical CNG issues which are normally encountered in other local CNG fitted cars.
It is related to Lamda controller plus the stepper mottor installed in it to control the gas flow.
The lendi Ranzo software which Pak Suzuki is using to adjust the lamda settings is not publically available to any independent mechanic atleast in ISB\RWP to date. And none of other s\w are compatibale.
These problems are very common in first few batches of these cars produced in pakistan, later on due to quite a huge number of complaints all over the country i came to know that they have reprogrammed the software and they have connttrolled this issue to some extent. [though i have reservations over this pak suzuki statemet]
what i think.... the only factor which is causing the malfunction of the stepper motor is the air flow....... with dusty air and varying CNG quliaty at different pumps its very hard provide lambda its operating environment and hence due to poor mixture the engine stalls or shutdown when you press the clutch to slow down. [Lamda is a sensitive system, and its not a success in dusy driving conditions here]
I agree with kaiser, Pak suzuki has failed to provide any sort of assistence in this regard,
with apologies i must say that some fellow here was mentioning to take ur car to Zafar at federal motors in abpara....i took my car to him some while ago and after all his efforts ( which spanned over 2 weeks of my contineous visits) what i was told is that... the car is perfect the probelm is with the CNG i am using
after that i have decided never took my car to any of suzuki dealer.
Kaiser,
if these problems are really bothering you then please go ahead with the solution which i have already told you
Sory guys for long post, but i had few things to clear.
Regards.
