Hello!
Well as for you info STYlzz....! I must tell you that
SE-G , XE-4WD ,LX 4WD and SE Limited 4WD Comes With 4A-FE 1.6L Powered Engine....!
SE Limited ,SE-L ,LX ,DX and LX Limited Comes with 5A-FE 1.5L Powered Engine....!!
There is one more class which i forget to mention is 4E-FE 1.3L Efi Engine...!
U can find it in
DX , LX , XE , LX Limited Comes Also With 4E-FE 1.3L engine.....! ( All JDM Varients I mention)
You can also find LX Limited and SE Limited in 2C Diesel but its very rear....! as normally not imported..!
So Here comes many Varients...but my actual point to tell you is that you can't find 1.6L in any SE Limited Nor LX limited till its 4wd model or SE-G...
SE-G is the only w/o 4WD varient came with 4AFE out....!
I say better check engine code before buying.....!
Regards
