the diff was from hilux.. which has stock LSD... the firewall and each parts was modified.. the good thing was. it was coupe.. and had bigger space in the driver cabin.. adjusted the firewall... and made it kinda tilt..... then the dasboard of indus was install all this was done in lahore... the trd supercharger kit was bought with the throttle boday, feul injectors, ecu wiring exyension.. water pump things and some pipes..
