Guys,
Need help I am looking to have modification is Liana LXI with
1.6 M16a MPFI VVT (Swift Sport 2012 - 2014)Compression Ratio 11:1???136 hp @ 6900rpm, 118 lb/ft @ 4400rpmWith 6 Speed Gear
required advise on this from specialist of Liana &swift
Yes what advise do you require.?I own a m18a powered liana eminent btw..And a x user of m16a non vvt and vvt m16 and also have driven m16gt in a swift.
Dani should is it possible local Liana manufacture be able to handle 136 HP. also if I put super & Turbo charger with it. I think in total 240 HP. Also advise how much it will cost M16A which comes in 6 Speed transmission
Yes dear brother on m18a I've done 180 many times and literally feel hi nai hoti high speed. Car is smooth on high speeds.
Around 1lacs for turboing it.And for tuner devices and wideband another 80kSo means 180k
Plus don't forget same chasis known as aerio handles j23 and j18 aswell
Thank you for the info and it will be costly upgrade
Shifting to m18a is not that costly. Turbi job is expensive. M18a non turbo would be more fun.
