there are different dynamos available which are rated for different rpms...
I have a generator that runs on 3000rpm, for example.
It's not a problem getting a dynamo for 1800rpm...
Also, your calculation assumes a flat torque-rpm curve.
you ignored dynamo efficiency which is usually around 90%+.
So the 75kw engine coupled with a decent dynamo can take a 65kw load at 1.0 power factor at max.
so it should be able to run a 75kva dynamo. look for a dynamo that produces 50hz/230V at 1800rpm. or the same at 2000rpm, then you can go upto around 100kva
