Today when i started my baleno 99 Glip. All the water of radiator came out from silencer then i pour water again and again and camed out silencer again what might be the problem.
yaar kise ko nai pta
check engine oil... it must have some "jhaaag" and must be thin.. if this is happening problem with your waterbody... will create problems for your rings and piston.
probably the head gasket died. but if thats the case there shud be smoke from the cylincer it doesnt works like a tap that u pour water in the radiator and comes out of the cylincer.
Check the oil if theres water in it.
Dude you shouldn't start your car now .. most probably the head gasket has blown (separates Oil and Water compartment) resulting in mixture of oil and water and will damage the engine seriously .. consult a good mechanic ASAP...
yeh agree wd ahmedzuhaib
